n249 valve bypass today...
Bypassing my n249 valve today.. going to do it in such a way as to leave it plugged in for now
Eager to see the difference it will make  :happy:
Look forward to hearing how this goes
I will take some pics.. apparently doing it this way means the electrical connection remains so doesn't throw a fault but the valve is bypassed on the vacuum side...
I did mine this way works a dream
Pics etc would be great. Im thinking of doing it more each day
Yh pics nd a guide would be good please
****e weather today chaps, hammering down here.. I will take pics tomorrow for you
And for the above comment... that link is for a total removal not a bypass!! One day I plan on a total removal but while this weather is here this works fine and only takes 10 mins to do
Good thing to do the simplification as its pointless having it electrically operated when it's a manual system... You'll probably find it drives smoother too
I am looking to do this shortly just trying to find a dry day when im off work.
Sent from my GT-I9505 using Tapatalk
Wish id of done a guide when i did it as i did it differently to most of the guides out there
This is one to add to the list. Ha ha
It's defo worth doing boys
Got excited reading this thread, had to google it.
Found this, Hope you don't mind me posting this on your thread : http://www.seatcupra.net/forums/showthread.php?t=348572
Then ordered the bits just for less than a fiver. :)
Sent from my iPad using Tapatalk HD
Mate that's fine..
And that is the exact way I've done mine.. noticeable difference and still no eml has come on
Edited by LuckyvRS20vT
All you need is...
A meter of 4mm vac line (I had a nice amount like left, about 20cm' s)
A "T" piece
And a couple of small jubilee clips and cable ties
10 mins of your time and wollah
Also, in the process you get rid of that stupid ugly black box that sits over coil 4 plus the bracket aswel
Get it done lads :-D
ByPassed my N249 just, DV is alot louder. :)
I completely removed mine at the weekend including all pipe work, and removed the SAI system at the same time.
I didn't notice much difference at all. Apart from the ASR system can't dump the boost now.
Sent with Tapatalk
Sent with Tapatalk
You get used to it, the asr still works just uses the throttle i assume
I think I have more hoses,  pipes and hard lines I removed than I got left on the car....  :rofl:
Yeah, the throttle will still close to cut the power. The ASR losing control of the bypass valve is a good thing. Used to annoy the hell out of me coming out of a corner and the boost disappearing
Sent with Tapatalk
Im retarded at car stuff and yet to find a decent guide to do it. So its staying!
Seriously there are loads of guides out there. Depends if you want to remove all the stuff or just bypass n249. To bypass is a 10 minute job as mentioned and very simple guides.
Sent from my Samsung S3
Whilst i have my engine out im doing the whole shebang
Its amazing how much ****e VW have put on these engines
I've just done this and now Im getting a lot of turbo flutter(not good). Any ideas why?
