electric problems
Hi first my centre locking went so can only open car with the key but only the drivers door opens. interior light and radio do not turn off when the key is taken out of the ignition and the door open Light on the dash stays on when the driver door is shut Please help
Moisture in the Central Convenience Module is a common cause of your symptoms.
Please can you tell me where the central convenience module is situated in the car
It's mounted centrally and conveniently :D
Heheh, it is under the front passenger seat. Hence, leaking door membranes or seals can allow water into the car, onto the floorpan and into the module.
There is also an outside chance that the driver's door lock module microswitch is faulty too - but check out this module first.
Take the car somewhere and do a Vag-Com scan first.
What model/engine/year is the car.
Most Mk1 CCUs are under the dash roughly above the driver's left knee and don't suffer from water ingress.
Thank you all for your help
