Fault codes 17524 and 17511
Driving and eml came on checked codes and these 2 came up lamba sencer? These 2 together does this point to new sencer or wireing thanks in advance
I would be inclined to check the fuse and feeds under the floor before going for a sensor on this, as it relates more to the heating of the sensor rather than the actual lambda function.
Anyone no where the fuse is located for lamba heat?
For my 2010 Octavia II 1.8TS, Fuse 15 (10A) protects the Lambda probe.
I think from memory, that it is fuse 43 on the vrs, in the dash fusebox, but check fuses 32 and 34 as well.
