n249 bypass question
Hi folks, ive done the n249 bypass today and well it all went to plan apart from the scratched hands :) but now my dv sounds really different, ive got the forge split-r and before the bypass it whoosed really nice and loud and now its not so loud and almost whooshes twice :o anyone else done this and experienced something similar??? :)
Was going to do it tomorrow, but if the noise is quieter then I'm not as I'm a noise freak.
People on the other thread said the noise was better/louder IIRC.
Is it more like a flutter ? From reading now, it can give a flutter sound.
Looking forward to peoples comments now.
Edited by mluton
I did mine..
Quicker spool and louder dump..
The dump is quicker
I did mine like the link in your thread lucky and mine dumps quieter and yeah it does flutter mluton, Maybe if I turn the dv round and see if that makes any difference... it was dumping nice and loud beforehand. Shall have to have a play around and see :)
generally the DV is a lot louder and more prominent after the bypass  as it is being operated mechanically. This is certainly the case with a std DV or a forge 0007p DV
Mines connected directly to the inlet manifold and not to FPR vac pipes. I now have a standard OEM DV and the OEM airbox and its almost as loud as when i had the CAI fitted
Any choice guides for the bypass? I may delete entirely but want to try before I buy so to speak. I have the silicone and t piece ready.
Sent from my GT-I9505G using Tapatalk
My guide is in the Octavia techical guide  section on SAI, N249 and N112 removal.
Will it make any difference turning my dv the opposite way round? Its installed sideways at the moment how the forge guide said to install iy, but im sure I read on here that the split-r can be used both ways :@ is this correct
Fit it standing upright,, this is how the standard one is fitted and it has to have  been put that way for a reason...
Mines up right and sounds awesome
Ah cool cheers lucky. Sideways on it does sound cool it flutters then dumps but not very loud :( is it loud???????
Edited by ricREDvrs
Split r will prob need adjusting again.
Any ideas on how many turns SNH? Or clicks???? Lucky how many clicks is yours set on? Is it split-r? Is your car mapped or standard?
Edited by ricREDvrs
The Forge and i beleive the split R can be reversed.
They do run ok both ways. However the forge sounds like a strangled cat reversed(not that i have heard one before anyone thinks I go out and test that theory).lol
Clicks?? No clicks here bud..
Yellow spring for mod/mapped...
Ok cos mine is set on 16 turns I think. Well thats what forge told me when I asked how to set it for the vrs. "Turn fully anti clockwise till stop. Then 16 turns clockwise to set for standard engine" I believe it can be set for full recirc with no blow hence the turns, but im a little unsure... maybe trial and error
Edited by ricREDvrs
16 clicks is correct on those for std setting
Cheers bowders1 :) think im gonna try it upright and see if it sounds anygood :):)
Did it sound any better, any issues since?
Sent from my iPad using Tapatalk HD
Still havent had chance to change it yet.. I know I know 5 min job but just been so busy with other things. Gonna do it tuesday and will report back straightaway :)
After doing the deletes and fitting a SFS Tip I set mine to fully closed sounds good dumping through the air filter. Mines stage 1 mapped.
Sorry forgot to say it's fitted sideways only way I could get it on with the new Tip.
Tried dv other way round and it sounded complete sh**e. So back to sideways on :)
