Front 312mm brake setup
Does anyone know if golf 2.8 v6 4motion calipers and carriers are a direct replacement on a vrs? Also will they be any closer to the wheels?
Yeah they're 312mm. of course will be closer but they do fit under the standard wheels I believe.
Front ones will fit with no issues, the rear ones will not, without fab work.
Edited by Gobsheene
Cheers. Dont suppose anyone knows how much closer they are, im on 17"et35 so standard calipers are close as it is
Completely depends on the shape of the back of the wheel and the spoke and wheel pad clearance so we can't really help you.
Test fit is the only way to check.
