Fault: Vehicle Lighting
On 23/05/2019 at 17:09, bgd1106 said:
When i'm connect with VCDS and i choose "Select module" error disappear. If i closed the VCDS, after a few seconds, error appears again..
This is start to happening now on my 2013 1.4 petrol octavia III 5e with xenons. I looked with ODB Eleven, no errors, no faults on any of the modules... And all lights/bulbs are working.... ????
  • 4 weeks later...
Have you fixed the problem?
  • 3 months later...
Guys, I had the same problem. Just had the car back from VW today. They updated the control units software and that solved the problem. Just ask your dealer to update the control unit software. Charged me £60 for it. Problem solved.
My BCM doesn't have an update. Can you tell me your number of BCM? Thank you so much!
  • 11 months later...
I have fixed this problem. You have to change the BCM with a new version. Now i have a bcm from 2018
