2002 VW Beetle MAF Fault
Hi all,
So a mate bought a 2002 VW beetle 1.6 SR for £400, no surprise it has some faults. he bought it as it was from a friend of his family, and his 2001 VW Polo was always on the brink of dying, due to the fact that he didnt maintain it properly. Anyway this beetle, The EML is on along with the ESP light. These engines have a MAF sensor instead of a MAP sensor.
The initial VCDS scan showed:
 Mileage: 173170km/107602miles
Address 01: Engine        Labels: None
   Part No: 06A 906 033 AK
   Component: SIMOS33 1.6l 2V 00HS4039
   Coding: 00031
   Shop #: WSC 00066
   VCID: 68D59ACD08F0C15E337-5140
3 Faults Found:
16487 - Mass Air Flow Sensor (G70)
            P0103 - 35-10 - Signal too High - Intermittent
17811 - EGR System
            P1403 - 35-10 - Regulation Deviation - Intermittent
16497 - Intake Air Temp. Sensor (G42)
            P0113 - 35-10 - Signal too High - Intermittent
Readiness: 0010 1001
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379 G
   Component: ESP FRONT MK60      0101
   Coding: 0011266
   Shop #: WSC 00066 000 00000
   VCID: 2E592CD5BA945F6E39B-5122
1 Fault Found:
01314 - Engine Control Module
            013 - Check DTC Memory
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605 A
   Component: 1T AIRBAG VW51 0D   0004
   Coding: 12628
   Shop #: WSC 00066
   VCID: 2241C8E5AE4CEB0EAD3-4AF6
1 Fault Found:
00532 - Supply Voltage B+
            07-10 - Signal too Low - Intermittent
Address 17: Instruments        Labels: 1C0-920-x4x.lbl
   Part No: 1C0 920 920 C
   Component: KOMBI+WEGFAHRS. M73 V08
   Coding: 01412
   Shop #: WSC 00000
   VCID: 1D3BFB199732D4F6901-4AF6
3 Faults Found:
01039 - Coolant Temperature Sensor (G2)
            30-10 - Open or Short to Plus - Intermittent
00562 - Sensor for Oil Level/Temperature (G266)
            29-10 - Short to Ground - Intermittent
            27-10 - Implausible Signal - Intermittent
cleared those faults, I reckon some of them were caused by the battery going flat. So in the end I took it for a drive, and then re-scanned and these faults persisted:
   Mileage: 173220km/107633miles
   Coding: 00031
   Shop #: WSC 00066
   VCID: 68D59ACD08F0C15E337-5122
3 Faults Found:
17811 - EGR System
            P1403 - 35-00 - Regulation Deviation
16486 - Mass Air Flow Sensor (G70)
            P0102 - 35-00 - Signal too Low
Readiness: 1010 1001
   Coding: 0011266
   VCID: 2E592CD5BA945F6E39B-5140
1 Fault Found:
So it indicated that the MAF/IAT sensors were faulty. However these are both in the same housing. Took it out, it looked fairly new, and i gave it a clean in electrical cleaner. The Fault persisted. I also measured approximately 3000 Ohms across 2 of the pins, and 4700 ohms across another two (4 pin sensor)
Ross-Tech says with both that if the sensor is ok, then there is an issue with the loom. Is there a way to confirm this? Someone has had a look at the loom before (left yellow PVC tape around the wires) and i found one had a nick in the insulation, going to bare copper, but the conductor was ok with no breaks or corrosion So i re-taped it and set it all back up as it was.
Thing i dont understand is aswell as VCDS, i also have a cheap ebay generic fault code reader. This reader can also measure real time data, which showed a reading for the MAF (in ibs/min) and also showed an Intake Air Temp of around 69 degrees Fahrenheit. I unplugged the sensor and the readings dropped to 0.00 Ibs/min and -40 Deg Fahrenheit, which indicated to me that the sensor was infact working as intended.
Just after a 2nd opinion really, any other suggestions than replacing the wiring loom? The ECU is placed under the dashboard and from what i can see, is a PITA to get to.
MAF is a common problem on Beetles, we have had a few older ones and pretty much all of them have had MAF problems, usually best to replace them, but get a genuine Bosch one as cheaper ones are useless, I tried a cheap generic one once and it just made it run like a bag of nails, put a Bosch on and it worked a treat, these can either be got from the dealer on an exchange basis or any motor factors will do one.
The Beetles are a good car, my wife loves them, she has had a few and despite the quirky looks and them being based on a mk4 Golf which is obviously old hat technology now, they are quite reliable cars.
Its also worth changing the temp sensor, as they can fail quite often, do that as well and it will prevent any problems.
Good luck with it, and at £400 sounds like a bargain!
Check for rust in the gutters on the roof, they can sometimes bubble under the insert strip, if it is, then if it has a VW service history then pop to a dealer and they have the ability to repair and respray that under warranty.
Well unfortunately the MAF was swapped to no avail! :(
although it wasnt new, it was with a known working MAF.
So it does appear to be the loom as there is nothing else it could be (which comes to mind)
thanks for the reply.
