Vague steering
So just had mot and asked him to look at wish bones apparently aio
But the steering is deffinately vague and tends to track easily there's also a very slight knock on dry steering
I'm thinking track rod ends or poss still wish bones any idea????
Edited by essexocty
Mine is/was a bit like this on long sweeping bends.It might just be my imagine but since having a wheel bearing done its a lot better.
Edited by GAZ911
Have you had a 4 wheel alignment done yet?, made a big difference to mine once done.
No I haven't but tyre wear is spot on making me think it's something mechanical
do you have play in steering column?
Hard to say but not a lot if there is, the car has only done 64k so I'm hoping its not a rack
if the play is in the rack is simple,you can tight the nut a bit and will gone
If is in the column you need a new one
