Specialized Pitch Pro 2010 mountain bike
For Sale - 2010 Specialized Pitch Pro Mountain Bike
Large - which is 19inch I think
This bike was rated one of the best you could buy for under £2000 and still is.
  Something with the same spec/travel would cost you £3000 upwards
This is classed as a freeride bike, meaning it will take anything you throw at it. Capable of anything from XC riding to full on downhill
I used it mainly for XC riding so it hasn't had a hard life and the condition will show that. For the past year it has been sat in the garage not being used
A lot of these I have seen for sale look very tired and heavily used and they still ask for £900 upwards,
But this is in brilliant condition and I am asking for less
Looking for £750
Collection only - Winchester/Southampton area
Upgrades I have made are Superstar seatpost and Superstar flat pedals, Hope Pro2 front hub, Ethirteen bash guard, Reverse bars
Original Specification:
Frame:
Pitch frame, M4 tubing, double ORE downtube, DMD front derailleur mount, sealed cartridge bearing pivots, replaceable hanger, bolt on cable guides, 150mm travel
Rear Shock:
Fox RP2, 2-position switch 1) ProPedal 2) full open, rebound adjust, 7.875×2.25 inch
Fork:
Rockshox Pike 351 for Specialized, 140mm travel, Solo air, Motion Control damper, disc only, alloy steerer, rebound adjust, Maxle light included
Front Derailleur:
Shimano M660 SLX, DMD, top swing, dual pull
Rear Derailleur:
SRAM X-9, mid cage
Shifters:
SRAM X-5, 9-speed trigger
Chainset:
Truvativ GXP2 2.2, 2 piece crankset, AA rings, outboard bearing BB 175mm
Chainrings:
36/24 tooth chainrings
Bottom Bracket:
Truvativ outboard bearing, included with crank
Cassette:
Shimano HG-50, 9-speed, 11-34 tooth range
Chain:
KMC X9 with reusable Missing Link
Pedals:
None
Front Brake:
Custom Avid Elixir 4, full hydraulic, alloy backed organic pads, G2 Clean Sweep rotor, 203mm
Rear Brake:
Custom Avid Elixir 4, full hydraulic, alloy backed organic pads, G2 Clean Sweep rotor, 185mm
Brake Levers:
Avid Elixir 4 Hydraulic
Handlebars:
Alloy mid rise, butted, 31.8mm, 680mm wide, 6 degree up, 9 degree back sweep
Stem:
3D forged alloy, 8 degree rise, 31.8mm 4 bolt clamp,
Headset:
1 1/8 inch threadless
Grips:
Specialized Thick lock on grip
Rims:
Pitch Disc specific, 26mm, pin joint, eyelets, 32hole
Front Hub:
Hi-Lo disc, 20mm thru-axle, 32 hole
Rear Hub:
Disc, double sealed cartridge bearing, high/low flange with OS contact side, 32hole, quick release
Spokes:
1.8mm (15g) stainless
Front Tyre:
Specialized Eskar Control, 26×2.3 inch, 60 TPI, tubeless ready, aramid bead
Rear Tyre:
Tubes:
Ultralight Presta valve
Saddle:
Specialized Enduro BG, 7mm hollow Cr-Mo rails
Seatpost:
2 bolt micro adjust setback head, 6061 alloy, 30.9mm
Seat Binder:
Alloy collar with quick release, 34.9mm clamp ID
Arghh, I've just spent that on a road bike.
Sort of thing I would be interested in when my MTB comes for change.
I am open to offers ;)
With the cash I have left it would be about £75. Think I can guess your answer lol
  • 3 months later...
Still for sale,
Price drop
£600
Sent from my Nokia 3210 using Tapatalk
Could this be boxed for a courier to collect?
I'll have this off you for £600.
Happy to collect in person but I'm out of the country until mid next week so can't collect until next weekend, Friday earliest. Can send you a deposit tonight if you like to secure the deal.
My brother lives in Andover. If you want it gone sooner I may be able to convince him to pop down one evening.
Chris
Chris
Ive been waiting two days for a reply, im meant to be meeting him tomorrow [emoji53]
Sorry pal. I was genuinely unaware.
Your previous post was over a week old and it didn't imply that you were making an offer. Therefore I thought it ok to make my own offer to which Lee has since accepted.
I've just paid a deposit and arranged collection before seeing your latest post.
^^ no problem mate its not your fault. It was arranged in the week but never had a reply about tomorrow. Guess its saved a journey
