1.9 diesel fuel pump not working advice needed.
Hi guys,
I’m after some help & advice.
I’m looking at buying a none running 1.9 diesel. The car was previously running but ran out of diesel one day but ever since has been unable to start. The guy has taken it to a local mechanic who has diagnosed a faulty injector fuel pump. So the guy has it up for sale.
My question is what’s the best way to approach this, should I replace with a secondhand unit or recondition the current unit and what would the cost be?
What guides are there out there to fault diagnose the issue?
Any advice would be appreciated
Rob
Depends on what pump it is. You used to be able to get pumps recon reasonabley cheaply but cost these days can be as much as a new one. Reckon anything between £200-£800 or above depending on whats wrong. Wonder if as it ran out of diesel did it suck up crud/water and filters are blocked? Some pumps have a fine gauze at fuel inlet. Not sure what car it is or engine but it may have an intank filter as well. Worth checking and replacing all filters first.
Alasdair
I agree at this moment in time it’s “how long is a piece of string” it’s getting delivered anytime now so will know more shortly.
Looking on eBay the cheapest is £156. I’ve spoken to 2 firms that do reconditioning and their combined prices range from £300 all the way up to the dizzy heights of £1500.
It’s a 1998 VW pick-up 1.9 but I can’t find any info on that anywhere but know there’s a big following for the Felicia pickup hence why I’m here.
Thanks for the advice reference the smaller inline filter, it’s the first thing I’ll check.
Had a quick look on wikipedia and if its a MK2 caddy it had a choice of four diesel 1.9 two N/A and two Tdi. I pulled this from AI
1. The 1.9 SDI Engine (Engine Codes: AEY, AYQ)
If you have the electronic direct-injection model, your truck uses a Bosch VE VP37 electronic distributor pump. [1, 2]
  • How it works: This pump relies on an Engine Control Unit (ECU) to electronically manage fuel delivery, timing, and throttle response.
  • Common Part Numbers:
    Look for Bosch 0 460 404 961 (VW OE ref: 028130082H) or similar Bosch VE series variants. [1, 2]
2. The 1.9 D Engine (Engine Code: AEF)
If you have the purely mechanical indirect-injection model, your truck came from the factory with a Lucas mechanical rotary injection pump. [1]
  • How it works: This is a fully mechanical, cable-driven pump (no ECU controlling the throttle).
  • Note for owners: The factory Lucas pumps are infamous for developing leaks or failures over time. As a result, many owners swap them out for a highly reliable Bosch VE mechanical pump taken from older VW 1.6D or 1.9 TD (AAZ) engines, which requires changing the mounting bracket. [1, 2]
  • Alasdair
That's falrly accurate, there weren't any turbo diesels in the Skoda Felicia car or Pickup, only the VW Caddy/ Seat Inca Van. Do you know if it's a D or an SDI (should say on the boot)?
The thing I would say though is never trust someone else's diagnosis. Daft stuff first, see if it's smoking out the exhaust when you turn it over, if it is, it's getting fuel in the cylinders. Check the cambelt isn't snapped. Give it a blast of brake cleaner down the air intake while someone turns it over. Make sure the stop valve is working, if you put your little finger on it, you should feel a little click as the ignition goes on and off. The stop valve should have 12v to it with the ignition on, if in doubt, take it out, remove the plunger and stick it back in (you might then need to stall the car to stop the engine if it's a D).
Then I'd start by doing a leak off test. unplug the return hoses from the injectors, find some hose the right size and run them between the outlets on the injectors and 4 containers the same size (500ml pop bottles work well). Make sure there's diesel in the car and at the filter and spin it over.
If you get a lot of fuel in a container. That injector's probably knacked.
If you get a dribble into the container, things are probably OK, particularly if they're all the same level.
If you don't get any, either it's out of fuel, the pump isn't pumping, or fuel the system needs bleeding.
After that, go with whatever you've got a tester for, be it fuel pressure, compression.
If it's solid, I'd go for it anyway, diesels aren't difficult. Worst case, it's got poor compression so it'll be easier to put an engine on. SDI's are easy to find, the older D's are getting a bit scarce.
Edited by StevesTruck
Steve that is brilliant, thank you. I’ve not played with diesel much but these few things you’ve pointed out will keep me busy for a while.
My only question is where/what is the stop valve is?
  • Alasdair
Interesting about the conversion to a different pump, I’m defo going to look into that.
On the pump, look for a wire going into what looks like the middle of a 17mm? Bolthead.
Did you find out if it was a D or SDI, or have you got the reg and I'll look it up?
Hi,
Yes I did, it the 1.9d and the pump on it is the Lucas 028 130 081c.
Hi,
I’ve had my first attempt to look at the issue and to be honest, I didn’t get far.
First of all I found that the diesel gauge isn’t working so I put 12l in. I then cranked it and was getting no fuel out or either the bleed nipple at the front or the injectors. My plan tomorrow is to disconnect the fuel feed pipe from the filter and try to prime the pump from there.
I looked and place my finger on everything that had a wire going to it but I neither heard nor felt anything clicking.
So, today’s questions are:
1, is there a lift pump in the tank or should the fuel pump draw the fuel up?
2, where is and what does the stop valve look like? I’ve google it and noting that’s coming up on my search looks like anything I have 🤷🏼‍♂️
I'm fairly sure there's no lift pump on a D, I know there isn't on an SDI.
Take a picture of your engine bay and I'll try to spot the stop valve.
Is there fuel in the filter?
Hi,
Can’t say if there’s fuel in the filter but there’s residue around the top. Does the filter need priming?
I’ve been searching the net and think I’ve found the fuel cut off and what I think it is is picture below. If that is it there was not “click” when ignition turned on and off.
If that is it any idea where I can get a replacement?
Try a live feed to solanoid. Cant see if its one or two wires. If it clicks with known 12v then it may be a wiring fault. You should be able to get one online. Dont suppose theres a part number on it?
Alasdair
Evening all,
So I had a play this evening until my battery went flat.
I put 12v to what I believed to be the stop valve as pictured previously and nothing happened. So I removed the fuel lines followed by the solenoid and what I removed is pictured below. On the bench I again put 12v to it and initially it didn’t want to move but after a couple of flicks of the battery + it was clicking away happily. I then put it back into the pump and wired it in but when I turned the key again nothing happened (no clicking). I checked what voltage it was receiving from the ignition and it’s only 7.3v but by taking a feed direct from the battery it would click.
Finally I tried to bleed the pump but nothing came out of the fuel pipes whatsoever.
Is what I removed the fuel cut off solenoid or something else?
What’s.
Does the VW pick up have a immobiliser like the Felicia?
Regards Rob
Right, that wasn’t it.
Nothing changed after removing the valve picture previously so the pump is now off. Even with the pump removed I could only see the two valves, one either side and the same as previously removed. So I did battle to remove the bracket and there it was hidden under the bracket that had no access or gap to see through. So the cut off valve was not functioning so I’ve removed it and hit that with 12v and again it free up and started to work.
My intentions are to remove the final valve on the side that also isn’t clicking give that a wiggle and that them all removed and hopefully all functioning correctly. Then I’ll cut a hole in the top of the bracket so I have access to the cut off valve without having to remove the whole pump.
My questions of the day today are, as I rotate the pump it rattles, is this normal?
And how do I time a Lucas 028 130 081c pump? There’s a plate on the back of the pump as pictured, do I remove this? There’s no access in the centre it’s solid metal.
Regards Rob
Not sure if it should rattle but read that you require special Dial test indicator guage with extension pin. The timing port is between the 4 high pressure lines probably under the centre cover held by the torx screws. From what I read it may be a garage job due to special tools required. Think you need a timing kit similar to this but never done the timing on a pump or used kit.
https://www.ebay.co.uk/itm/407231762606?_ul=GB&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338990945&toolid=10001&customid=eb%3Ag%3Avms%3Aeb%3Ap%3A407231762606%3B{GCLID}&_trkparms=ispr%3D1&amdata=enc%3A1bOpTAGwuTgCovN2XgM0sDg18&adtype=pla&loc_interest_ms=&loc_physical_ms=1007345&gbraid=0AAAAADmMgijEi4U_EoAkfDTnHUDpZymg-&gclid=CjwKCAjwrP3VBhBbEiwAnaqpQ3sIxepuyRFIVgqn445Yt38JNYxVo1X4VALkEP6LuFDj6Cj_nLhr3RoCsrwQAvD_BwE
Alasdair
As to rattle the pump should turn smoothly with some resistance at certain points. If its rough or rattling I reckon its probably had it. If something internal has failed it could feed debris down fuel lines and wreck injectors. Dont suppose you have a diesel specialist near by that could take a quick look for you.
Alasdair
I can't help with the engine, since I've never worked with the diesel, but I just want to make this clear
MK2 caddy are actually two entirely different models, funnily, neither of the two was made by VW.
The van (9K) is rebadged Seat Inca, derived from MK2 Ibiza (6k). It's a mix of different VW platforms, including mostly MK1 caddy, MK2/3 Golf and MK3 Polo. The SDI and TDI engines were only available for this variant.
The pickup (9U) is rebadged Felicia Pickup (6U). The AEF engine is the only diesel available, it originally came from MK3 Polo. Unlike the other VW diesel, it's slanted forward to fit into smaller engine base of the Polo and Felicia. Apart from the engine and some individual bits here and there, there's nothing from VW, even the gearbox is Skoda with adapter plate. Keep this in mind when looking for parts.
@Rsedmonds Since the engine was also used in the Polo, you can try their community, there were probably more Polos with this type of pump than Skodas.
Edited by Papez
Hi all, just a quick update.
So after taking the two solenoids out that didn’t need removing I removed the whole pump but I still could only see the two solenoids. I then saw a picture of another Lucas pump and there was a cut off solenoid at the end like other pumps but on my pump I couldn’t see it until I took of the mounting bracket and there it was.
Cutting a long story short I had power going to a module on the base of the pump but no ignition power coming out. I removed the solenoid leads from that module and put them to the ignition power to the module, earthed the other end and BOOM I now have a working injector pump and after bleeding the pump I now have the pick up running 💥🎉
Thanks for your help guys without your advice I would still probably be chasing this one.
Rob
