Tickover Rpm
Sat in the inevitable stop start Que in heavy traffic in my 2011 fab vRS! I was very bored!
Passing the time I have noticed that in D revs are about 850 rpm on Rickover but if I select S or go to manual mode they rise to just above 1000! Is this normal?!? Just an Observation????
Yes its quite normal mine does this also.
All normal.
Ta was just wondering!
Yep 100% normal. Allows for speedier get-away :-)
I'd check your oil ;)
Maybe its to help you take off abit quicker!
The rev-up when you change into S is a bit of a giveaway to clued-up "opposition" - do it before you pull up... :rock:
Doesnt matter what the opposition think, if your quick enough ;).
No need to bother with  S for those sort of shenanigans...D can be lary enough if done right :giggle:
Does the same if you go into Manual mode as well..
