Coolant mixture G13 ratio
Did my stat this morning, all went to plan. Happy bunny.
I put in 2x 1.5l of g13 and just over 1.5l of water in total and it's at max.
Is this mix ok or a bit to strong. Shall I drain out a litre and top up with water ?
Is 50/50 the correct mixture ?
Cheers, Matt
Edited by mluton
IIRC, the coolant capacity is 6.8l so you should be fine. If you assume the previous concentration was 44% (3l in 6.8l), then you will now be at 60%. If you really want to know, buy a cheap coolant tester.
Cheers, it's dropped 1cm now after using it, but going to let the car cool and check again in a bit, so I'll top that up with water.
Sent from my iPad using Tapatalk HD
