running et19 on a mk1 fabia !
hi all
i have been told by pretty much everybody that my new wheels arent going to fit but am not giving up since cost me alot of pennies
the spec of the wheels is as follows 17" 8j 5x120(with adapters to 5x100) 16mm et35
now i do realise that the poke is going to be stupid but is there any advice people can give me other than your an idiot or mad/ wont fit
i will be getting arches rolled and pulled
cheers guys
Fit 195/40 tyres.
try them on
if they rub.. get arches rolled
they WILL fit the rear 100% with NO modification
they might poke about 4/5mm at the front + will omly catch if your low. You can modify the front arch liner to stop them catching so probably wont need rolling either ;)
Are your wheels BBS RC090's by any chance?
Rears will be fine front may poke abit for some peoples liking but will fit. I have et16 8.5s on the rear now and when I get my bbs on they will be et10 8j 17 inch. You could afford to go to 20mm spacers on the rear.
I bloody hope not, he does say they are et35 to start so I doubt it.
no there not mate but they have been a ballache had to buy spiggot rings adapters and now 4 new 195 40 17 tyres and away to archwerx on saturday to get arches modified
atm mate my back wheels is tucked under the arch and there is 10mm of room between arch and tyre wall now willitfit.com say that comapred to my setup now wheel will stick out 31mm more -_-
On standard wheels with no spacers?
no there 17" octavia spiders joe you have me on instagram the black fabia with candy red wheels ??
what wheels do u have atm?
U shudnt have to modify rears
i had 17x8.5 et21 on my rears before i had my arches rolled n still room
if uv got tyres n adapters then fit the wheels ;)
Then see if they need any arch mods on the front.. tbh u can modify the front arch liners yourself.. no need 2 pay sum1 unless they 100% need rolling
CANDY RED!!! U cant have owt these days :( lol :D
looks better than it sounds mate but new wheels are white so had to change everything to white haha
well atm i have 17 inch spiders with thhe adjusters taken out on the coilover and nicely tucked but everytime i hit a bump or anything it catches a bit or smacks of the arch liner i assume ? joe how low are you on back and front so you dont think need to get arches rolled just get the liner taken out and should fit fine
cheers guys
The spiders are only 7j and im assuming your running 205/40 tyres so the tyres will be sticking out + thata whats catching.
you will be fitting 195/40 tyres to 8j wheels so the tyres will be slightly stretched. This in itself will reduce the catching ;)
and i didnt mean the candy red will look bad. I was gutted because my current wheels are candy red too lol
will post up some pictures later and well anyway am going to get all archliners removed and stuff and go from there am i right in thinking fabia front arches are already rolled or not
and to clear everything up i will be running on ET35 with 16mm adapters so will stick out 31.7mm from hub i think
but cheers guys that gives me a bit more confindence
Edited by stevek66
ahh well i will changing mine soon and what candy red did you use i had to buy it of ebay the specialist paint and was 50quid a litre looks nice when its clean and shiny but trying to keep it that way is impossible !
Iv run et21 7.5j fronts with 195/40 and they were fine your guna be running et19 8j so with more stretch on your 195/40 tyres so the wheels will poke abit more (my 7.5s werent even flush) but the extra stretch will mean you will have extra room.
they arent rolled already but if you cut about an inch of the arch liner from the top half + remove the top screw + plastic bit it screws into you will catch less..
its worth doing before u get em rolled because they will be cutting that bit off anyway to roll them ;)
My instagram in @m9yty if u wana see the fitment i was refering to
mine were powdercoated candy red whats ur instagram? Iv been wanting to see how the paint turns out ;)
have started following you mate and tagged you in a picture thats how it looks now but just the wheels to go on now ! and engine bay is gana be all white as well !
nice :)
I wana get my engine bay dun candy red.. but i know if i start doing it ill wana smooth the bay n it will end up off road for months n months ha
Are you _wilfred?
yes thats me joe !
Sent from my GT-I9300 using Tapatalk
Ah that's what threw me haha, I was like...I can't remember a Steve with red spiders?
yeah I just put random names on these things mate ! you going to else car joe wana see your car in person I love it !
No it's abit far for me and I won't be long back from Las Vegas so I will be skint. I will be at inters if your going.
yeahh should be pal :)
