Pd130 injectors in a pd100 are they just plug and play
As above do pd130 injectors is it just a case of swap them over and that's it or or they have be set up
I thought my thread had been cloned. My bad haha.
Haha lol I have just looked at your thread see if it says in there lol
I know they fit and are easy to swap. Someone said they fitted them with no remap and had abit of a power gain so I guess they are plug an play!
Had no one say they ain't I guess.
They dont need setting up.
BUT
when you fit em they have to fitted straight.. not just banged in ;)
Dno if there is a guide on here but i use ElsaWin + you basically use a flat rule and measure them to make sure they are straight.. easier to explain with a pic lol
I "think" in theory the car will tell it to inject XYZ like it told the PD100 injectors, and the PD130 injectors will do the same.  However, if the XYZ is a signal based on a range of injection, and the PD130s inject about 30% more, in theory you'll probably get 30% more fuelling at all times.
They are plug and play in theory, but really should be mapped by someone that knows what they're doing.
Cheers for the replays guys ????
