What's difficult apart from the weight ? And any special tools needed? Its a six speed on 2007 plate.
What exactly are you asking? :D
Edit: im on my phone so cant see any sub titles if you have put some explanation in there lol??
Erm......Right....Psychic ability time....
I'm guessing you mean removing the gearbox? Changing the clutch?
Clutch replacement aparently. :)
A hammer?
in that case.
With a ramp not a problem. Only special tool is the clutch alignment tool but that is not needed. You can use a drift or align by eye ;)
Without a ramp the 6 speed is awkward to get in. Comes out ok.
also you will need to bleed the clutch because of the internal slave cylinder. You can do this without a tool but a pressure bleeder makes it 100% easier :).. iv just bought an Eezibleed (probably spelt wrong) so i can bleed brakes/ clutch at home.. £17 delivered. Not used it yetbut my m8 has n said it was spot on :)
Thanks for info it was reference replacing clutch at home on drive have ramps or will support car on chassis rails, how long should it take approx ?
