06 VRS Front Fog Lights Wont Turn Off
The front fogs on my Fabia won't turn off, doesn't matter whether the headlights are on or off, as soon as I turn the ignition on, the front fogs come on.
Any ideas?
has your car always been like that?
No, it's a new feature, started a week of so ago!
Automatic fog light wa***r   :giggle:
You'll have to explain that one to me!
  • Sponsor
If it were me, I'd take the bulbs out and be done with it.  However...
It almost has to be a faulty light switch, I think?
Find someone local you could do a swap with, see if your fault goes away, and they gain the full-time-irritating fog lights.
I can't remember the details just now, but it's quite easy to remove and unplug the light switch assembly, turn one click and pull, or something like that.
I think you push it in and twist to the left
I can change the switch if that's the problem, easy enough.
I suppose I could just remove the bulb but that would leave the warning light on the dash which tells you the fog lights are on,
It's the switch, £8.50 on ebay, push in and twist like matt said.
I have one in the garage I think, fully working!
Doh! Remembered I'm no longer freedom
Edited by JoshH
It's push and twist to the right. As if you was turning the lights on
