VCDS Error 22 When Trying to Code Bluetooth on RNS 315
Hi Guys,
I'm new here, and to the world of Skoda.
I've just picked up a brand new 14 plate Roomster, unfortunately I didn't get to spec the car myself (Special Edition), but I though I would be able to swap out the Swing Radio for a RNS 315, run the mic cable, tick the box in VCDS and away I go. But... when I untick the box in the long coding section and then click Do It, it throws back an error code 22, and doesn't code the option.
I've tried coding other options, like disabling AUX2 for example, and the same thing happens. So I am assuming it's not related to the bluetooth option itself.
Could it be something in the CAN gateway that I am missing or something? I'm not sure where I should start looking with this.
Any help would be very much appreciated.
Cris
Not all of the RNS315/Amundsen+ units have BT fitted, best way to check is to look for a MAC address on the headunit. If you don't see one or they are all zeros then unfortunately it doesn't have BT.
Search on forum as there is a picture of the label your looking for.
If your following my how to and ticking the box and you get an error more likely the answer is not fitted.
What software version of VCDS are you using?
I am using 12.12
I checked the label before fitting, there is a MAC code on it.
No option will program, so I don't think it's the lack of a BT that is the problem. I can't program the code to the RNS315 at all. I can put it into developer mode, so I can talk to it, just not code it.
Cris
I've got the only one listed under the Skoda section on that link.
I think the RNS315 I have is not correctly coded, but I don't know enough about VCDS to understand what the errors I am seeing mean, here are the outputs from the scan (edited down to the problem areas)...
Chassis Type: 5J (6N0)
Scan: 01 03 08 09 10 15 17 19 25 37 44 56 77
VIN: TMBPM65J5E5028913
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
56-Radio -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 5J0 920 911 M    HW: 5J0 920 911 M
   Component: KOMBI         H02 0408
   Serial number: 00000020120521
   Coding: 410A00
   Shop #: WSC 33361 790 00099
   ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01723
   ROD: EV_DashBoardUDSJCIPQ25_SK25.rod
   VCID: 3261028865D1A08E527-8067
1 Fault Found:
13654544 - Databus
          U1121 00 [009] - Missing Message
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 12
                    Mileage: 56 km
                    Date: 2000.14.31
                    Time: 17:12:49
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 6R7 937 087 P
   Component: GW-K-CAN TP20 H30 0565
   Revision: -1------
   Coding: 832300
   VCID: F0E54880235D529EE43-80A5
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 - - - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 52
                    Mileage: 56 km
                    Time Indication: 0
                    Date: 2000.14.31
                    Time: 16:48:28
Address 37: Navigation (J794)       Labels: 1K0-035-27x-37.clb
   Part No SW: 3T0 035 192 K    HW: 3T0 035 192 K
   Component: RNS315-EU   H59 0324
   Serial number: SKZAZ2N0164579
   Coding: 040004210405000000018001
   Shop #: WSC 33361 790 00083
   ASAM Dataset: EV_RNS315EUV2UDS 001705
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 36693E9889B9BCAE7EF-8063
   Data medium:
   Subsystem 1 - Part No: 3AA 919 866
   Component: EUR_W_V4  0050
7 Faults Found:
1048578 - Supply voltage
          U1011 00 [008] - Voltage too Low
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 41
                    Mileage: 8 km
                    Date: 2001.14.30
                    Time: 16:20:27
1048580 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 41
                    Mileage: 8 km
                    Date: 2001.14.30
                    Time: 15:29:48
1048632 - Antenna 1 for Radio
          B1119 13 [008] - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 67
                    Mileage: 9 km
                    Date: 2002.14.03
                    Time: 15:31:26
1048634 - Antenna 2 for radio
          B111A 13 [008] - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 67
                    Mileage: 9 km
                    Date: 2002.14.03
                    Time: 15:31:26
1048582 - GPS Antenna
          B1054 13 [009] - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 9 km
                    Date: 2002.14.03
                    Time: 15:31:26
1048636 - Digital Radio Antenna
          B1103 13 [008] - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 67
                    Mileage: 9 km
                    Date: 2002.14.03
                    Time: 15:31:26
1048659 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 27
                    Mileage: 205 km
                    Date: 2001.14.00
                    Time: 09:32:38
Control Module Part Number: 3T0 035 192 K
  Component and/or Version: RNS315-EU   H59 0324
           Software Coding: 040004210405000000018001
            Work Shop Code: WSC 33361
Advanced Identification/FAZIT
     Identification: YD5-001
     Date: 07.03.13
     Manufacturer number: 0024
     Test stand number: 0003
Flash Status
Software
     BAP: 00.2F.01
     CAN: 01.02.00
     Theft prot.: 01.02.14
     ISO15765: 00.00.01
Misc.
     Hardware number: 3T0 035 192 K
     Workshop System Name: J794
     ASAM Dataset Revision: 001705
VCDS Info:
Here is a screenshot of the error VCDS throws up when I try coding the Nav module...
Clear all the fault codes and try again, they look like they have been caused by disconnecting wires with the system still live.
The gateway errors and cluster errors should clear once the RNS is coded correctly.
Having an 'incorrectly coded' error on 19-CAN Gateway would be my starting point.
It is basically an 'instalation list' that needs the correct options ticked.
Maybe Bluetooth or something hasn't been ticked to enable it in the list.
Check there and post screen shots of the list if possible.
Then clear the codes and see what comes back as it is likely most/all have appeared as a result of changing the headunit.
That is also my guess, but I can't code the RNS315 at all, it throws back an error 22 (see the screen shot above), and then I'm stumped. So I thought I would try and pick few brains here.
It's really getting on my nerves now. I've tried clearing the codes and starting from scratch, still comes back with the same error 22, and coding I do gets rejected.
Is it possible that the gateway on my car is not comparable with the module in the RNS315 ???
Cris
Your gateway appears to be from a Roomster and fairly recent, so no reason why it shouldn't be.
Have you sent a full scan to Ross Tech (assuming you have a genuine cable & a support package)?
What are you trying to code in the 'Navigation' controller?
Have you unticked 77-Telephone? AFAIK that is for the external BT / telephone module not the inbuilt one. Just wondering if that is causing a conflict (doubt it though).
untick 77 as the BT is in the Radio
although I don't think it is that that is stopping the coding
Cleared all the codes, re scanned and only had one fault left, that was the GPS antenna and I know that will show as a fault as it isn't connected! Unticked 77 etc...
Still the same, error 22 thrown back every time I try to code it. Tried all sorts, just about to give up on it and maybe try another RNS 315.
It seems strange that I can't code any option onto it.
Any further ideas before I go splash some more cash ???
Cris
37 - Navigation & 56 - Radio are (in a Columbus) basically the same thing.
Coding changes in one are reflected in the other. Have you tried coding it in 56 - radio?
Have you checked that both module shave the same coding applied?
I don't think it works like that in the RNS 315. Tried it, I can't code anything as it says module not found. I don't think this is related to the Error 22 issue I am having.
Cris
try coding it again but add 00 to the end
Just run out to try it, throws this error...
I tried something different, I tried to program back the exact same code that is reported to be in there already, I get the same Error 22 !!!
So it is nothing to do with the code I am actually trying to change, but the ability to code the RNS315 at all !!!
I think that is a little step forward in my understanding of this problem.
Cris
Have you contacted Ross Tech?
I will do.
I'm thinking that this unit might be faulty anyway. It's not keeping station presets etc....
I was leaning towards that conclusion myself. But not knowing the specific error codes you are getting I didn't want to say anything.
Yep, faulty unit. Tried another one today, codes up fine with bluetooth etc...
Now a very happy Skoda owner :)
Cris
Hello, How do you know it is faulty unit? Have the same issue, my RNS315 is not keeping station presets and other settings. Maybe it is something not compatible.
