Fitting Toyosport Decat to Jetex Cat-back
Has anyone done this?
What will be required if anything!
Anyone?
Hi buddy, I have a Toyo Sports decat fitted to my piper exhaust system.
I would expect your Jetex to fit in a similar way . You probably got a sleeve with your jetex (if new), but even this might not be enough as you will probably need to extend the toyo decat like i did
Rather than mess with lot's of joiners and sleeves i had a new section welded to the deact to then be able to just slide the center section over it.
Cheers Bowders,
You reckon its worth modifying the toyosport pipe rather than getting a milltek?
Cheers Bowders,
Price wise yes....cost next to nothing to weld a straight section
ease of fitting a Miltek straight to your exhaust , probably no.....go for miltek.. :rofl:
Will need to have a few bits done to the car before Stage 2 I will add to my list.
I reckon Dynodaze nextdoor to R-Tech would knock something together along with fitting the new TIP and deletes.
