help please
Running temp is fine, so dont think its thermostat, any ideas where temp sensor is located?
Edited by ricREDvrs
Thanks for response... any ideas where the sensor is located?
Think it's as you look at the engine it's on the right side of the head on the coolant housing has a black U shaped clip and black multi plug. Sometimes the temp sensor is a light green and sometimes a grey colour. You will loose coolant when removing and recommend replacing the seal and clip as the clips can break.
Hope this helps dude
 Replace with a genuine VAG part only. Buy cheap buy twice.
Cheers all. Shall get a genuine part and change asap :)
Yep genuine only. ECU won't be fuelling correctly.
