Tints or Blinds Octavia MK2 Hatch (FL)?
How the hell do the rear blinds fit? I've got the side windows in ok, but the rear window clips just don't seem to fit?
Are you talking about the Skoda blind or the Van style ones?
With the Van style blinds you have to kind of hook the clips over the plastic trim then push them down to seat them......from memory I think you had to prize the trim out slightly with your fingers to get clearance to get the clips in.
It's the ones with clips, ie not a roller version. I thought these were genuine skoda as they came with the car and look a perfect fit but I could be wrong.
AFAIK, the clip on rear screen ones are vanstyle or other, not OEM. OEM is roller.
Fair do's - thx. Mine are 2 piece with a clip in the middle of them, so assume non OEM. When I manage to fit them I'll decide if I want to keep them in or not - I have the side rears in but the back may be a bit restrictive on vision.
They are the Van style blinds then.
If I remember correctly they supply different clips for the different windows. The clips for the rear window are quite large to enable them to fit over the trim. The other clips will not fit at all......So make sure you are using the correct clips......I think I made that mistake when fitting mine.
Figured it out now :) seems that I was missing 2 clips, which I've now found and managed to get them in fine :) look good too!
Excellent!  :thumbup:
