Superb 4x4 DSG
Hi
What Average MPG Are people getting with there Superb 4x4 SE 170 DSG Combi cars ?
Cheers.
Mine only covered 2100 miles but happy so far, avg is in fuelly sig block below.
I've just bought a new estate 170 4x4 DSG and mine is significantly lower than my previous 140 manual. However the car is a lot heavier of course.
Early 40s mainly but yet to go on a long trip. Only 500 miles from new so far.
Engine hasn't loosened up yet - although mine is a 140, the MPG considerably improved around the 10-12k mark.
You can see mine below. It's on 12000 ish miles and is DSG. My mileage is mainly city with an occasional long motorway/A road run. The car is far less economical on long runs than my previous car a Saab auto diesel convertible (regularly 46/48 mpg), overall though it is better than the Saab, which suggests it is more efficient in the city.
Hi
Thanks for the info,33 mpg Is low I would of thought these cars would be doing around 42-45mpg average at
Least.
Cheers.
In my case - city 38 mpg (almost no traffic jams), motorways (100-130 km/h) 44 mpg.
PS. Start-Stop is off all the time
PPS. I like sporty driving
Hi
Thanks for the info,Does the Superb 170 cr 4x4 dsg have stop start now ? ,When was that fitted to them.
Cheers.
Yes the 170 cr 4x4 dsg has start stop fitted, I think it was done as part of the facelift changes
Yes, it has start stop now. Luckily switch off button is added as well.
Although the off switch is handy (especially if you are stopped at a junction ready to move off!) the start-stop does make a difference to fuel economy and I wouldn't dismiss the system.  I don't have a 4x4 but I can certainly attest to getting better mpg versus the pre FL without the system
I have had mine for 8 months and have just gone round 23,000 miles, returning average of 44mpg including several trips towing a 1600 kg caravan. Slightly less than my 170 FWD pre facelift
Hi
Thanks for the info,What is it like to drive with the 4x4 and DSG would you recommend it over a manual also what is the steering like
Do you experience any Vibrations through it while driving
Also what is the ride like on 17 or 18" wheels
ride is fine with 18's I'm running 19's and it's not made the ride any more crashy.
DSG is smooth and effortless, the 4x4 transmission doesn't vibrate either. the best bit is you put your foot down and it goes without fuss!
You get used to it so when you get back into a 2wd dsg, you (or at least I do) end up wheel spinning by mistake, not very often but it does happen because you forget! :)
Hi
First of all - if you aim at 4x4, then you won't have many options to choose between DSG and manual. Out of 4x4 versions 170 Hp diesel comes only with DSG, 3.6 petrol - also with DSG only. 140 Hp diesel 4x4 comes only with manual. 1.8tsi 4x4 also with manual.
I have 170 Hp diesel 4x4 DSG
good acceleration (no wheel spin)
quick gear changes
handy manual shifting option on steering wheel (additional option)
tends to put too high gear when cruising (! - seems like it is improving over time, 6000 km done)
engine vibrations and idle and at low revs (! - improving during run-in period).
Steering is good, but not ideal. Steering wheel is correctly weighted, but it is not a sporty car - it is big, you get some body roll. I have it on 17's and you can feel and hear all the potholes and road imperfections.
