Which Coilovers?
Feedback depends what you're trying to achieve and what you're budget is i guess?
  • Sponsor
As above, what were you looking for from the coilover kit?
Damian @ DPM Performance
Easy to fit and adjust
cheaper
lower than springs
firmer ride
will be adding rwar arb at some point
budget 400 max
I've got the FK ak streets and there not a bad ride tbh.
How are they on the dampning? I do a lot of miles so I dont want it mega harsh. I do like the price though but a bit worried about how long they will last / build quality at that cost.....
Seem to be ok, I run low so they'll be harsher than if they were 20-30mm lower than standard
Spend a bit more and get AP's.
Or spend even more and buy H&R Twin tube coilovers :D
Ok, big question!!? Are fk better than standard? Ie in build quality? Will they last longer? Or are you buying and fitting an inferior product?
The FK's were the only ones that would give me the amount of adjustment I wanted. The more you spend the better they'll be no doubt but I can't fault them. There not harsh by any means
