Removing oil filter on 2007 PD engine
Can anyone point me in the direction of what tool I need to remove the oil filter on a standard 2007 PD Octavia (BKD engine)?
I'm getting conflicting information from the internet but, at the moment, believe it to be a 32 mm socket that I need.
Can anyone confirm if this is correct or post slink to the correct tool if its not.
Thanks.
32mm socket sounds right. I think it says the size and torque on the cap.
Yep. 32mm but you may need a universal joint too.
Thanks trundle nut and rover 220.
I don't see any specific sizes marked on the cap of mine (but then I wash;t actually looking for a size at the time).
Would one of these be overkill? Or is that the best way to do it?
I just bought a normal 32mm socket from halfords, and then discovered my socket set had one already...
