ABS fault
Morning All
Ive had warning lights come up on the dash, being the ABS light, the ASR below the blower dial and the car with the squggle lines. My friend used his device to read the faults and we got:
00290 - 035 CAN BUS AB£ Wheel Speed Sensor : Rear Left (G46)
Any ideas?
Morning All
Any ideas?
Really mind-blowingly big clue ;)
I think its the hub as wheel im getting a droning noise!
Probably a rusty magnet in the wheel hub rather than the sensor. Needs a new hub I'm afraid. If you can have a look at the inside of the hub, if you can spot the ring rotate the wheel and check for any missing chunks. They rust, bits fall out and the error comes up.
