Suspension parts info
Hi all
Broken front spring so changing shoocks/springs.
Also going to change the top strut mounts and the drop links. Does anyone know the part numbers for these?
Dave
Edited by FatblokeVRS
http://www.skodaparts.com/product/octavia-front-suspension-top-mounting-2004-2013-30183 + bearing (see below link)
http://www.skodaparts.com/product/fabia-top-suspension-bearing-2000-2007-34579
Personally unless worn I haven't needed to replace my drop links for a shock change as I have no problem removing them with a proper spline bit + soak with plenty WD40 overnight
http://www.skodaparts.com/product/octavia-front-antiroll-bar-link-rod-2004-2013-30182
Thanks for that mate. That is extremely helpful.
I had a look on the web yesterday and there were so many different bits it was very confusing.
I cant believe how expensive the drop links are. I will maybe try and re-use the originals.
