Replacing ccu
Got a replacement ccu arriving soon, once its fitted do i need to reprogram my keyfobs for the locking or is that controlled by something else?
Yes. You need to learn the key fobs. If this a second hand CCU, erase any existing fob data (write 0 to channel 0), before learning your key fobs.
The locking/unlocking of the key fob has nothing to do with the engine ECU. Only the chip in the key
Sent with Tapatalk
Sent with Tapatalk
Correct. Writing 0 to channel 0 OF THE CCU erases all previous key data.
Don't forget to disconnect the battery earth before starting... prevents anything going fiz pop lol
Yeah its a second hand ccu. I take it using the method seen on youtube, one key in the ignition and one in the drivers door is the right way to program them?
Is that available on vcds lite?
Anyone know how much skoda charge to reprogram keys to new CCU's? Vcds lite wont do it
