headgasket advice pd130?
Disconnect breather pipe off inlet,unclip top cambelt cover, cam cover off if its a ASZ engine, if its a BLT you also need to loosen off the inlet manifold so it can be pushed backwards slightly to gain room to remove one of the bolts.
Bit fiddly to do unless you've got girls hands!! :)
Cheers mate :)
Is that bolt torque formula correct also??
