Just a quick wheel question
I've got a 2010 Octavia vRS FL with standard 18" Neptune wheels. Is the hub spacing 5 x 100 PCD or 5 x 112 PCD?
5x112 mate. 57.1 centre bore. M14x1.50 bolts .
Jon
Thanks Jon.
Your wheel dimensions are 18" diameter, 7.5" wide with an offset of 51mm. Otherwise known as:
18x7.5J ET51.
Factory fit tyres are 225/40/R18. Can't remember the load rating off hand.
M14x1.50 bolts
Are you sure about the length Jon? Seems awfully short to me. ;)
M14x1.5p x 27mm long. ;-)
Didnt say a length mate ;) m14 means 14mm and the 1.50 indicates thread pitch, but as above, should be around 25mm-30mm long as standard and have a radius seat.
Jon
Edited by _redders_
