Cisco 1841 - Talk Talk Configuration
Hi All,
Hoping you can help. I have recently replaced a terrible ISP router with a Cisco 1841 router which seems configured correctly however ever since connecting this up I am having very weird internet issues..
For example when trying to browse a webpage it will give me "page cannot be displayed" however if I try a few times it loads but not correctly - However if i get the website to load correctly after a good few times it then seems to load OK (As if it is cached) but as soon as I go on a webpage I have not used it either slow or "page cannot be displayed"
I tried plugging my technicolour router back in and I get normal internet again. Please see below the config and advise me if anything is incorrect. The internet is that intermittent I have had to plug the Technicolour back in until I get a resolve.
I have DNS / DHCP running on a Domain controller - The router is simply the default gateway & the device my ADSL plugs into.
CCAuthorized access only!
 Disconnect IMMEDIATELY if you are not an authorized user!
User Access Verification
Username: username
Password:
talktalk.router#sh run
Building configuration...
Current configuration : 3279 bytes
version 12.3
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname talktalk.router
boot-start-marker
boot-end-marker
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
ip subnet-zero
ip cef
no ip domain lookup
ip ips po max-events 100
username username
no crypto isakmp ccm
interface FastEthernet0/0
 description (Inbound Connection to Fortinet Firewall))
 ip address 192.168.0.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly
 duplex auto
 speed auto
interface FastEthernet0/1
 description ((Connection to Playstation 4))
 no ip address
 duplex auto
 speed auto
interface ATM0/0/0
 description Connected to ADSL Line
 no ip address
 load-interval 60
 no atm ilmi-keepalive
 dsl operating-mode auto
 hold-queue 224 in
 pvc 0/38
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface Dialer0
 description Bound to ATM0
 ip address negotiated
 ip mtu 1458
 ip nat outside
 encapsulation ppp
 load-interval 30
 dialer pool 1
 dialer idle-timeout 0
 dialer persistent
 no snmp ifindex persist
 ppp authentication chap callin
 ppp chap hostname
 ppp chap password
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer0 overload
access-list 1 permit 192.168.0.0 0.0.0.255
control-plane
banner login ^CCCAuthorized access only!
 Disconnect IMMEDIATELY if you are not an authorized user!^C
banner motd ^CCC
^C
line con 0
line aux 0
line vty 0 4
 transport input all
end
talktalk.router# exit
I have also tried plugging direct into fa0/0 (Which is where the Fortinet device sits) and giving myself a static IP and I still get a kind of intermittent Internet connection, which is cleared up if I plug in the router provided by talk talk.
I suspect I have a config error somewhere however the router is not providing any feedback so your feedback would be great.
thanks
  • 2 months later...
After banging my head on every wall in the house and having my father patch up the plastering I finally found a configuration that works with Talk Talk if you opt to use a Cisco router. The configuration is below - I have *** the personal config which will need replacing with your configuration.
I am even kind enough to provide you with a MOTD :D
** *                        !!! WARNING !!!                        * **
** *    You have accessed the network operated by *************    * **
** *     You are required to have personal authorisation from      * **
** *    the system administrator before you use this device and    * **
** *      you are strictly limited to the use set out in that      * **
** *                     written authorisation.                    * **
** *    Unauthorised access or use of this device is prohibited.   * **
** *    Unauthorised access or misuse of a computer constitutes    * **
** *       an offence under the Computer Misuse Act of 1990.       * **
Enter configuration commands, one per line.  End with CNTL/Z.
talktalk.router#
talktalk.router#
talktalk.router#
Current configuration : 5466 bytes
! Last configuration change at 21:21:53 UTC Tue Jun 17 2014 by ***
version 15.3
no service pad
boot-start-marker
boot-end-marker
no logging buffered
aaa new-model
memory-size iomem 10
crypto pki trustpoint TP-self-signed-1
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-15287***
 revocation-check none
 rsakeypair TP-self-signed
crypto pki certificate chain TP-self-signed-15
 certificate self-signed 01
  3082022B 30820194 A0030201 01 74652D31 35323837
  31373439 3330819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100991E 4CC964C2 3C808F6E 53B890F2 56D3E448 1CC2BBF2 E26C0C13 12432C0A
  08D4**************
  quit
no ip domain lookup
ip cef
no ipv6 cef
license udi pid CISCO887VA-M-K9 sn FC*******
username *****************
controller VDSL 0
interface Ethernet0
 no ip address
 shutdown
interface ATM0
 description Connected to TalkTalk BB
 no ip address
 ip flow ingress
 load-interval 60
 hold-queue 224 in
 pvc 0/38
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
 shutdown
interface FastEthernet3
 no ip address
 shutdown
interface Vlan1
 description LAN Interface
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat inside
 ip virtual-reassembly in
 ip tcp adjust-mss 1452
interface Dialer0
 mtu 1492
 ip flow ingress
 ip nat outside
 encapsulation ppp
 load-interval 30
 dialer pool 1
 dialer persistent
 ppp mtu adaptive
 ppp chap hostname **********@talktalkbusiness.net
 ppp chap password *************
 no cdp enable
ip forward-protocol nd
no ip http server
ip nat inside source list 101 interface Dialer0 overload
ip nat inside source static tcp 192.168.0.67 443 interface Dialer0 443
ip nat inside source static tcp 192.168.0.67 25 interface Dialer0 25
ip nat inside source static tcp 192.168.0.65 3389 interface Dialer0 3389
ip nat inside source static tcp 192.168.0.67 80 interface Dialer0 80
access-list 101 permit ip 192.168.0.0 0.0.0.255 any
access-list 101 deny   ip any any log
banner motd ^CCCC
** *    You have accessed the network operated by ************.    * **
^C
line con 0
 no modem enable
line aux 0
line vty 0 4
 access-class 101 in
 transport input all
end
_____________
Ignore the IP NAT Statements - They are an example incase they are needed - I use these for Exchange Server.
This also has no DHCP configured as I am running DHCP separate. If you require DHCP you will need to add this by running the command
IP dhcp pool *DHCP POOL Name" IP Address, Subnet mask
Glad you got it sorted, by talking to yourself! :D
I'm no use, as I never deal with Cisco kit....
Yeah there is no guide out there that helps with Talk Talk and Cisco Kit that works... I thought by posting on here the configuration that actually works it should be a high traffic post :)
