Dsg flashing gear numbers and key
Hi
I drive skoda octavia II 61 plate 1.6 tdi dsg with 69k on the clock . When I was driving home I found out that gear numbers on dashboard started to flash and key ( service key) appear and flash as well . Gears change normal , car drives good . I stoped , switch off car , switch on and it was fine . Everthing back to normal . But after 5 miles it started again .
Any advice wlecome .
Cheers Mike
Only thing to do is find someone local with VCDS to scan for the fault code which will have been logged when your problem appeared. Having said that, your car being a 61 plate should still be in warranty so I would get it into the dealer pronto.
Ian
Thanks I will go there asap. But because of millage car isnt on warranty any more :(
Yes just remembered about mileage, though I would say you have a very good case for goodwill from Skoda.
Ian
Good will is possible if warranty has expired. I had all my rear brakes and passenger side caliper replaced with good will. I just paid 10% of the bill.
if you don't ask yiu don't get.
P17BF Hydraulic pump system - overload protection
That is  a problem . Car is in a garage for a weekend .
I also notice that car goes in to limp mode
cheers M
  • 2 years later...
cheers M
Hi MikePl, I have the same problem with my VW Golf MK6 1.6 TDI DSG. Could you be so kind and share with how you solve this problem? Thank you in advance
Hello, is anyone knowns the solution?
Over two years ago! Doubt it.
