What is the max depth for mounting front speakers
I have 45mm depth speakers at the moment, and like a set of 57mm deep ones i have seen.
Will these fit in std holes without hitting window reg or other stuff?
cheers
I got jl c5s mate
2 secs and i will check depth
they will fit at the limit... :)
I have magnat speakers with 56mm mounting depth and they touch in one spot the door's structure,but is nothing
Mounting depth of them be 65mm bud
Yeah theres like a lug of sorts
Iirc i heated it and bent a tab back
Ha ha my mate cut a lug off and then i filed n painted it
Nothing major
I had a pic of it when done.... I'll see if still have it
Ah cheers mate, good to know :happy:
65mm jesus.. on std door adapters?
Nothing major
Yeah i did the same years ago , cut off corner lug, painted it and put a bit of insulation tape over when fitted speakers last time  :rock:
Yep :) in they went mate
I dont recall any other adaptor ;)
And still in oem door pod bud
Unless they made them deeper now, but yeah they arnt shallow :D
Mine has a set of focals in sounds well
So when you say standard door adapters, do you mean the MK4 Golf adapters? Or just drop straight in a stock door?
I think mine are just plastic rings that are part of the door fitting that speakers fit to. Don't think they are after market ones. Could be wrong.
