2.0T Petrol VRS ? Turbo Issue
Hello,
I have a Petrol VRS - which has been a cracking car so far!!
My wife mainly uses it - pooling around - and i use it occasionally, and open it up a little more.
My commented on a Temperature rise a couple of months ago - where the temp gauge went right up and then back down again.
Not straight away - but a couple of weeks later - accelerating - the car revved up to 3.5K and then dropped revs - this has happened repeatedly in every gear.
I had my chap plug the car in last week - several codes popped - including temp sensor, air valve and something to do with Turbo.
He cleared codes, serviced - oil and filters etc - this needed to be done anyway.
It has happened since - but now it revs up to 4.5k revs and then drops revs. And today the engine warning light has come on.
Up until yday - although it was dropping revs - no warnings codes had come up when the car was plugged in.
I am aware of the issues with the DV, if it hadn't have changed the rev cutting out range today - i would have suspected this more - but now that it has I'm not sure??
temp sensor, air immitence valve, DV Valve , Turbo????
Any ideas would be much appreciated.
Many Thanks,
Alex
It would help if you quoted the fault codes, and hope someone else has seen them as it's not always a straightforward diagnosis as I found out last year.
Sent from my ME301T using Tapatalk
