Fabia Noise from Dashboard
Hi i have a fabia from 2000 a 1.4 16v.
The problem is that there is alot of rattle / noise from the dashboard. I have search and found this page:
http://www.briskoda.net/forums/topic/17163-dashboard-rattle-on-fabia/
I can see there should be a guide but i can not find it. Anyway i have removed the center air vents but i can find the place where i have to put the rubber a described. I have uploaded a picture. Can you tell me what i have to do next / put the ruber ? Sorry for my bad english. I hobe you understand. Thanks for the help. It is appreciated.
Hi Kristian
Not had this problem but I hope you manage to fix it
Chip
When I had this problem, my mechanic also tried to remove the glovebox, but without any luck. We finished the task with a very long screw driver, a small piece of rubber and one drop of super glue (to temporary attach the rubber to the screw driver head).
I finally found out where the rattle came from. I have some weeks ago adjusted the steering wheel due to back pain. Today I tried to set the steering wheel back to default position now the rattle is gone ? I guess I will live with a bit awkward sitting position rather than that rattle noise is drives me crazy.
Edited by schumi112
