Turbo clip adaptor/coupler
Getting some custom pipes made up for a SS cooler and was just wondering if you need the turbo clip coupler thing or can you just bang a bit of silicone hose onto it? And what diameter is the outlet coming off the turbo? (PD150) cheers
You will need an adapter to allow fitment of a normal pipe :)
Just what I didn't want to hear :( lol can only find darkside who do them and they're fifty odd quid !
Danham changed his I think.
Coupler about 18 on eBay
Any idea of the size you need as I made some myself at work and have a few spare
I couldn't tell you mate that's what I'm wanting to know, I know it's smaller than the intercooler ones
Forge do them!
They're not that expensive either. Call them and ask to speak to Kris who comes on this forum now and again as there's 2 of them there.
He will sort one out for you. All you need is the seal from your original turbo pipe to put on the coupler :)
Forge do them!
I think it is G dan yeh ! Cheers mate think I'll get that ordered today !
http://www.forgemotorsport.co.uk/content.asp?inc=product&cat=0016&product=FMABHC
I'm 99% sure it's G that you need. Call them though.
Btw same coupler fitted my KKK pd130 and my Garrett pd150 turbo :)
are all the couplers the same shape dan just different sizes? The one I've got going into the top of me standard intercooler when I did the hard top boost pipe is that size so I might get away with using that hopefully !
is that for the turbo?
Wouldn't wanna say for gertain incase I;m wrong but I think it's the 51 - 50mm for the turbo side and 60 - 51mm for the intercooler side
My intercooler one is 50-51, I bought the 60-51 but it was too big. So I think the intercooler one I've got will go into the turbo so I won't have to buy another, I'm gunna check over the weekend anyways
Mine were both the same shape, the turbo one has a slightly longer piece for you to clamp down onto though :)
Best to try it really just incase, once under tray is off it's quite easy and there's loads of room.
I don't run an undertray anyways ! Will give it a go this aft :)
Hello guys, I also need the turbo clip, does anyone know:
A. How much the Forge one comes to inc VAT and delivery?
B. If the eBay one is any good!? Also the actual size needed for the clip
Ps eBay one seems cheaper, is it worth paying the extra for a Forge one?
The one you see on eBay is creation motorsport?
They are a bunch of *****. For that reason I would pay for Forge even if it was double the price :)
Haha! Any reason why you don't particularly like them? Are there products any good or is it that their customer service is poor?
Is it defo item G that I need? Please can someone confirm, really want to order one tonight!
Ring forge they might knock some money off for you if your a forum member :)
I don't like them because they sell poor quality and when questioned he turned nasty so turned into a hilarious slanging match.
Thanks for the insight mate - think ill stick with Forge in that case!
  • 2 years later...
Has anyone noticed the standard coupler is reduced down in the middle? I was just going to put oversized silicone pipe over the top of the female end off the turbo but noticed the standard coupling was reduced so just ordered a smaller pipe and gunna salvage the old coupling and go to that in case its reduced for a reason i.e. Back pressure or stop to much boost going in the intercooler anyone know why it's reduced?
  • 3 years later...
 Ph1lly87 I think its because turbulence is created not sure . Now im looking for the coupler to fit rubber hose on the turbo. The coupler from darkside cost almost as much as pipe kit for my intercooler! Would that fit for standard turbo?
