DIY Mufflerectomy guidance
So thinking of making my own mufflerectomy. Just wondered if people would be able to confirm what I'm doing is right?
So I'm gunna but some 2.25" pipe just 1meter. So the outside diameter is 57mm
Going to get a tip and the inside diameter is 59mm
So there will be 2mm of play in the connection. Will that make a difference when welded?
Finally when connecting the new pipe to the existing is 2.25" the correct size?
Thanks in advance
James
I just used some old exhaust and a tip for mine and welded it all together
do you have any videos of it Kyle?
If you look on Instagram I'm kyle_vrs there's a few on there but I'm running a decat and s2000 filter too
cheers bud will follow ya!
