Error code P0171 P0441 P0116
Dear Techies,
I have a skoda fabia kompis 2002 , 1.4 60HK and now its time for yearly inspection test. The car has been giving low milage , 10km/1 liter max. I was in the workshop and they did a data test and found the three (3) error codes - P0171, P0441, P0116. the check engine light was on and off frequently.
The workshop told me to change Front Lambda sensor, Tempareture sensor exhaust system, AKF ventil/AKF Valve. The workshop gave me 1200 USD charge for that including service. So, I thought to do it by myself partial works.
After that I went to a small workshop and change the small joint pipe in the exhaust pipe which add two exhaust pipes. After that I did a OBDII error code erase with my Vgate VS450 scan tool and the codes are not coming back for 3 weeks and 200 km run. After the exhaust pipe fix the check engine light never come back for 2 months. But when I put the OBDII with ignition ON, its visible in the dahsboard. What does that mean ? This is my first question.
Second question, shall I change the parts recommended by workshop directly or do you have any advise ? I have checked internet and find the below solution. It does not say to change the parts as the workshop saying. Please advise.
16555/P0171/000369
Contents
16555/P0171/000369 - Fuel Trim; Bank 1: System Too Lean
Possible Causes
  • Mass Air Flow Sensor (G70) defective
  • Intake System Leak(s)
Possible Solutions
  • Check Mass Air Flow Sensor (G70)
  • Check Fuel Pressure Regulation
  • Check Fuel Pump
  • Check Injectors
  • Check Intake System for Leaks
  • Check Exhaust System for Leaks
  • Check Secondary Air System for Leaks
  • Check Vacuum Pipes for Leaks
Special Notes
16825/P0441/001089
Contents
16825/P0441/001089 - EVAP Emission Control Sys: Incorrect Flow
Possible Symptoms
  • Malfunction Indicator Light (MIL) active
Possible Causes
  • Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80) faulty/jammed
  • Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115) faulty/jammed
  • Evaporative Emission (EVAP) Canister Sealing faulty
  • Pipes between Tank Breathing and Throttle Body leaky/blocked
Possible Solutions
  • Check Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80)
    • Perform Output Test
  • Check Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115)
  • Perform Basic Setting
  • Check Pipes between Tank Breathing and Throttle Body
Special Notes
  • When found in the NAR 1.8T Audi A4 1.8T check TSB 24-08-78 or 2010268/3 or Pass-Thru equivalent TSB
  • When found in the NAR 1.8T VW Passat 1.8T check TSB 01-09-09 or 2005554 or Pass-Thru equivalent TSB
    • Note: The Passat 26E5 or "R5" recall includes the same software update
  • Make sure the quick release lines for the N80 valve and vacuum line to LDP are not crossed.
  • This can also make the engine hard to start after filling up the fuel tank.
