service help for vrs
Hi,
Just wondered if someone could help, I've got a 2011 fabia vrs and it's done 7000 miles, it's been serviced twice since I got it and it's had the oil and filter changed on both occasions by non skoda garages. Could tell me if I need a major or minor service and whats checked?
thanks
Your Service Schedule was, if keeping to it.
1st service,  @ 12 months/ 9,400 miles,   'Minor Service',
So thats done.
2nd service, @ 24 months,
'Major Service'  'Inspection Service', includes changing Pollen Filter.
**If it was a non Skoda Dealership that serviced, then the 'Inspection part',
checking the Body for damage etc, may not have been done, you have a Service Stamp,
but not a Skoda/VW Health Check done.***
Depends who serviced it.
3rd service @ 36 months, 'Minor Service',
& @ 3 Years Brake Fluid Changed,  & MOT needs doing.
(Maybe you want a new Air Filter, you want it checked,)
Before the car is 3 years old & out of Warranty, get any Warranty Work done.
Be sure that a ECU Update has been done.
Your car is so low mileage, so you need to talk over with a Mechanic/Technician what needs doing.
If you are going to Buy an Extended Warranty for the next Year or 2,
you need to stick to Recommended Manufacturers Servicing and parts/fluids..
So thats done.
thanks for the reply, would it be worth in doing a major service as the other 2 have only been minor?
If you car is 3 years old, it needs the Brake Fluid Changed,
It needs everything fully Inspected and Checked,
Steering, Suspension & Brake parts, Pad Wear etc.
 Tyre Walls checked were you can see & on the Other Side you can not..
Its not done lots of Miles,
but still Wiper Blades, Brake Pads etc can be as worn or needing replacing as a car thats done
40,000 miles.
So just a good Maintenance Inspection before the Warranty Expires & before the MOT.
If not at a Skoda Dealership, maybe at a VW One.
Under £200 possibly. £250 ish,  Service, Pollen Filter, Brake Fluid Change.
But i would check who ever is doing it Understands what you want,
'The Car Properly Serviced & Checked all over'.
Not Just Fluids/Filters/Grease & a quick look over, a Proper Check.
If keeping the car.
Skoda have a 'Service Plan for car from 3-8 year old.'
It includes 2 Services, Minor & Major when you want them done and 2 MOT's.
It might work out good for you price wise.
http://skoda.co.uk/about-us/news
