LCR front end on a 4x4?
Just a quick one!
Can any parts from a LCR front end be used on a 4x4 octavia?
If not they'll be in the for sale section! ;-)
Mark
Hubs arms can steering rack can't
not the hubs
not the hubs
Hubs carriers can, but the hub/bearing is for 2wd
Need those from a R32 or press out the original 4x4 ones and fit into the LCR Hub carriers
On the Octy 4x4 you want to keep its oem hubs
Flatter geometry than the R32 ones ;)
putting Octy hubs on an R32/S3/TT would be an upgrade ;)
Edited by snow_muncher
Right cool
I'll keep hold of it for now! ;-)
Cheers guys
really how come.
I suppose depends on how low car is.
As the R32 / TT hub will make control arm sit lower so if the subframe is low this will surly balance out more horizontal no?
this is correct, however the R32 wishbones to Octy Hub at level ride height sets up for good min. ride height vs articulation on firm suspension, any lower risks cracking your sump open & rubbing tyres
