crankshaft sensor?
hi there we are having a problem with our 2002 octavia estate 4x4. most of the time from cold ( occasionly will do this warm if left hour or so. i will start the engine and sometimes it will not fire fully it is running but sounds incredibly rough chugging and idle up and down . other times it will start ok go to pull out and it will conk out . with around 2-3 restarts it will start and run perfect . any ideas? i did have a problem where it completely died and had dash lights everywhere and i changed the fuel pump relay as per advice and it worked but going downhill lately
You need to get it scanned.
hi ive had it scanned a few times and it comes up with banking sensor 2 o2 thing. and a maf fault :)
p0101 code for maf i believe
been reading its possilby a coil pack issue? i have disconnected the maf at the min and will be changing it to a spare that my dad has to see if any difference
Crank sensor would show up on a scan
Also contact skoda to see if you can have 4 new coilpacks for free under recall :)
will do thanks brownbarge . since disconnecting the maf sensor i have no problems starting up :s
i was wrong - still stalling when pulling off from first start. i have changed coolant temp sensor as i had  a code come up for that. and cleaned throttle barrel. i have read that if the car runs no different disconnecting the maf then its had it and need changing? i wasnt able to try my dads spare as it didnt fit so would it be worth buying a new?
