service advice
So the vrs is due a service, last one was 15k ago, I know the brake fluid needs doing, but other than that what should I get changed?
Its my mates uncle doing it as he works for Mercedes. He said oil, diesel filter, air filter, glow plugs, oil filter but is there anything else? If someone could supply a list that would be great.
also where should I buy the parts from?
Thanks.
Eurocarparts for parts or if you want genuine VAG parts, TPS.
Glow plugs are not a service item, I wouldn't replace unless they break.  My car has done 130k and is still on original set.
The other items you mention depend on the mileage you have done and what was done at last service.  If you don't know the history all the above (except glow plugs) would be worth doing:
Oil & filter (get a new sump plug and crush washer), proper PD oil is a must, i.e. approved to VW 505.01 or 507.00.
fuel filter
air filter
fuel filter
air filter
Thanks, cars on 105k now and was on 91k when it was last serviced if that helps?
If the service book is up to date, that will give you a clue as to what need doing.
When was timing belt and water pump last changed?
They were done recently, within the last 25k I believe. I'm going from memory at the moment though as im at work and my service book is at home.
Maybe check the wear on your pads and discs as well.
Air filter is actually every 40k but I change mine @ 20k
don't forget the pollen filter :)
Maybe clean the EGR system if it hasn't been done before. Not service affecting but it wouldn't hurt the car :)
