Have what looks like a coolant leak help
Hi guys just noticed this leak
Any ideas?
Pictures a tad blurry lol
Yeah sorry will try and get a better one shortly
Is that coolant or hydraulic fluid?  I can't quite work out where you are, but I guess the clutch slave cylinder won't be too far away.....
Mine started leaking - it turned out to the flared end of the hydraulic pipe (changed the slave first, and then had to change the rigid pipe after)
I'm not sure the reason I thought it was coolant was cos it's a pink colour like the coolant it's near enough on the passenger side of the car but you could be right about hydraulic fluid cos it's right by the gearbox to be honest I've no idea :-(
Have you gave it a sniff?
Yeah doesn't smell of anything
Looks like coolant to me check the coolant housing on the right side of the engine where the temp sensor goes might be the seal for the temp sensor or the housing itself quite common on these, hope this helps?
Ok just took the engine covers off wish I hadn't :-(pesujeba.jpg
Plus injectors look covered in oil
Had the same issue, coolant was leaking from this housing on the gearbox and the it dripped underneath.
Sent from Tapatalk
Sent from Tapatalk
Yeah pretty sure that's where it's coming from did you just replace the housing ? And how much did it cost if you don't mind me asking?
So just been out and cleaned all the grease and dirt off the engine and soaked up the coolant puddle up should be easy to see where it's leaking from hopefully :-)
Cheers dude very helpful :-)
