CAN gateway incorrectly coded, causing major issues
Hi Guys..
Tryjng to rejuvenate this thread as very relevant.
Please help ive just tried to code a new CAN gateway and really balls it up!!!
The car battery seems to have drained and wont even jump start either..
Ive reverted long coding to as it was.. but in my haste when i made changes to installation list i didn't note which options were originally checked..
Im guessing if I have a list of those I can work backwards n start again..
Btw CAN gateway is flagging up incorrect coding fault also..
Please offer your much needed expertise
The incorrect coding fault should tell you which controllers are installed but not configured in the gateway.
^^^^^ What he said :)
Do an auto-scan, it will tell you what is installed and mark as incorrectly coded.
Use the installation list, not long coding as a couple of things changed (Steering Angle Sensor is no longer 00 for example) Go by name not by number.
Just noticed that I can't be that far from you if you need some help.
Cheers guys ... mike advised me above last night which seems to have corrected the coding apect.. however the columbus didnt have any sound following..
Also just woke up n tried to start car again the battery is drained!!!
Cant figure it out...
Yes trundlenut weve met before you kindly let me sort out DPF while my vcds lead was with a friend..
Sent from my GT-I9505 using Tapatalk
My car is 56 reg Vrs
Columbus unit is
1Z0035680 A ..with firmware update reads as 3T0
HW H04
SW 1004
BT MODULE
7PS 035 730K
7N0 907 530F CAN Gateway..
To my knowledge all components are compatible.. what am I doing wrong
What firmware have you gone for? That model of Columbus can only go to 4020...
Yep Adamal did the 4020 firmware... playing about with VCDS again this morning seems the sound returned upon coding unit as vw unit rather than skoda..
Just doing auto scan now see what else comes up now all dtcs have been cleared. . Cant figure out consistent battery drain.
VIN: TMBEH21Z478013949   License Plate: EU56VNZ
Mileage: 96871mi   Repair Order: 1234
Chassis Type: 1Z (7N0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72 76 77
VIN: TMBEH21Z478013949   Mileage: 155900km/96871miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Cannot be reached 1100
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine        Labels: 03G-906-018-BMN.clb
   Part No SW: 03G 906 018 EL    HW: 03G 906 018 EL
   Component: R4 2.0l PPD1.2 G    9953
   Revision: --H22---    Serial number: SKZ7Z0F3701570
   Coding: 0000072
   Shop #: WSC 00191 264 15243
   VCID: 73EE1BF612A55486965-8026
No fault code found.
Readiness: N/A
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
   Component: ESP FRONT MK60      0101
   Revision: 00H11001
   Coding: 0006786
   Shop #: WSC 73430 790 00000
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1Z0 907 044 H
   Component: ClimatronicPQ35 084 0305
   Shop #: WSC 00000 000 00000
   VCID: 3B7EF3D67A75DCC68E5-806E
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000004312102
   Coding: A1880F030004140000110D000000000000087F075C
   Shop #: WSC 73430 790 12345
   VCID: 2B5EC3968A154C461E5-807E
   Subsystem 1 - Part No: 1Z2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SK351  012  0401
   Coding: 00063477
   Shop #: WSC 73430
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD0N7VH+
   Coding: 0020788
   VCID: 3D7AFDCE6461D2F6B01-8068
   Subsystem 1 - Serial number: 6332MSME1227474DB
   Subsystem 2 - Serial number: 6342MSME12033368+
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BC    HW: 1K0 953 549 BC
   Component: Lenksäulenmodul 035 0070
   Coding: 0000042
   Shop #: WSC 24073 576 95090
   VCID: 74EC18EA17AB53BE8FF-8021
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1Z0 920 912 E    HW: 1Z0 920 912 E
   Component: KOMBIINSTRUMENT VD1 1610
   Revision: V1610036    Serial number: SKZ7Z0F3701570
   Coding: 0001401
   Shop #: WSC 01220 001 18229
   VCID: 3776EFE6465DF8A66AD-8062
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 AF    HW: 7N0 907 530 AF
   Component: J533  Gateway H52 1634
   Revision:   H52       Serial number: 120213F1000982
   Coding: 351307
   Shop #: WSC 12345 123 12345
   VCID: 74EC18EAD7AB53BE8FF-8021
1 Fault Found:
00474 - Control Module for Immobilizer
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 2
                    Mileage: 155903 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:30:46
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VD1 1610
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 3T0 035 680 B    HW: 1Z0 035 680 A
   Component: RNS-MID       H04 4024
   Revision: AB001001    Serial number: SKZ6Z7H6060084
   Coding: 06010400040100A0000D
   VCID: 2F66D7867E0D306632D-807A
1 Fault Found:
00856 - Radio Antenna
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 2
                    Reset counter: 2
                    Mileage: 155896 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:26:59
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
   Component: Tuer-SG         005 0954
   Coding: 0000756
   VCID: 3874ECDA4B43F7DE637-806D
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.074 H07 1806
   Shop #: WSC 01220 001 182299
   VCID: 356AE5EE5C510AB6781-8060
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0202
   Revision: 00020000    Serial number: 00000000000000
   Coding: 18801A085283007F3F04850540085F96907CA0
   VCID: 830ECB36C205E406065-80D6
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.008 4801
   Coding: 00000000
   Shop #: WSC 73430
   Subsystem 6 - Part No: 1K0 951 605 B
   Component: LIN BACKUP HORN H07 7001
   Subsystem 7 - Component:       NGS n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Component: Tuer-SG         005 0944
   Coding: 0000756
   VCID: 3972E9DE7049EED69C9-806C
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
1 Fault Found:
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 2
                    Reset counter: 2
                    Mileage: 155896 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:26:59
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 1K0 959 703 J    HW: 1K0 959 703 J
   Component: Tuer-SG         005 0907
   Coding: 0000144
   Shop #: WSC 73430 790 1012544
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 1K0 959 704 J    HW: 1K0 959 704 J
   Coding: 0000144
Address 76: Park Assist        Labels: 1Z0-919-283.lbl
   Part No SW: 1Z0 919 283 B    HW: 1Z0 919 283 B
   Component: Parkhilfe 4-Kan H04 0020
   Coding: 0000001
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007663746697
   Coding: 0A00000000010100
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
   VCID: 3A70F6D2BD4FE5CE953-806F
2 Faults Found:
9458195 - Control Module for Cellular Telephone
          B1052 13 [009] - Open Circuit
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 2
                    Mileage: 155903 km
                    Date: 2000.00.00
                    Time: 09:28:47
13636352 - Control module not coded
          U1013 00 [009] - -
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 2
                    Mileage: 155903 km
                    Date: 2000.00.00
                    Time: 09:28:48
End   ---------------------------------------------------------------------
Coding as a VW unit might give some red lighting. The sound might be to do with the premium sound system option being ticked and not having it or vice versa if coded as Skoda.
The battery drain seems very odd given you have updated the gateway - have never heard of that one. Perhaps it is worth trying the 1200 vuci file on the Columbus if you haven't already as perhaps you have unmodified 4020 firmware causing a problem. The vuci 1200 file does the modification I think.
Adam
Im guessing the ones highlighted in blue are just due to the antenna set up on a Columbus being different to stream.
Which leaves
Telephone,
Immobilizer which cant be reached for diagnosis
CAN Gateway
Cheers Adamal i did expect the backlighting to turn vw red when i did the coding but remained green, but as you suggest the coding does have premium sound checked, so ill take that off and revert to skoda unit.. see if that works!!
I cant seem to source the vuci file is it normally installed within the firmware update???
PM me your email mate and I will send the iso across.
Pmd
Guys can anyone help any further with this..
   Coding: 351307
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 2
                    Mileage: 155903 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:30:46
   ROD: EV_UHVNA.rod
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 2
                    Mileage: 155903 km
                    Date: 2000.00.00
                    Time: 09:28:47
Nothing I do seems to alleviate the signal to immobilizer fault code or that of the telephone although telephone and BT are functioning fine.
The second one is alleviated by unticking microphone diagnostics or similar I think.
Have you definitely got an immobiliser - might simply be ticked and not relevant?
Yes. Columbus has 2 aerial inputs and Stream only 1. The aerial sould be connected to the one closest to the centre of the unit as it does both AM and FM. The other only FM.
Cheers guys... yeah i thought it would just be the antenna..
Er ok at risk of looking like an absolute muppet.. doesnt the vrs come with immobiliser standard.. I thought it was alarm that was opt extra
Oh adamal also the original can gateway taken out of car was coded with immobiliser in installation list.. does this not suggest there is one
Shinzagi
Total guess on my part for the immobiliser!! You are probably right it is standard but just thought I would rule out the obvious! Mike's point is pertinent too...
Adam
Every car sold in the UK since about 1996 has had to have an immobiliser fitted as standard.
Did you have the immobiliser fault showing with the old gateway?
Once you have installed the new gateway, remember that AT ONE POINT before it was coded correctly, it will still have been connected, with the ignition on, with the coding WRONG, so will have stored various fault codes throughout the other modules. You will need to go through ALL the installed modules and clear the fault codes in EACH ONE before doing a final code clear of the new can gateway.
As said, a retrofit Columbus will ALWAYS bring up fault codes in its module as there is only one antenna lead to two inputs on the radio. Even with an aerial splitter the fault code still appears.
Also worth noting is that if the car has got a retrofitted maxidot unit -- in other words if it didn't originally have a maxidot -- then you will get an immobiliser fault because the EEPROM in the cluster has been overwritten. The immobiliser (which is standard fit on all Octavias) will still work perfectly even though it shows a failure fault in the VCDS scan.
A further point to mention -- the original gateway only has one engine module as address 01. The 7N0 has both Engine 1 and Engine 2 modules. Make sure only the engine 1 is selected.
Mike
Cheers Mike missed this post!!
I have gone through all modules and cleared all fault codes, then have gone back to CAN Gateway and again cleared fault codes, once you close controller and restart vcds, the faults marked above continue to come up.
Adamal kindly sent me a vuci iso file to upgrade to my firmware currently on 4020.. succesfully done , so now with updated modified firmware and correct vuci file to fix battery drain, correct gateway, what the hell am i doing wrong!!!!!
Once again the battery is flat as a pancake!!! the battery is in good working order checked my meter and alternator all working as should.
Never knew that but makes sense, cheers.
