throttle at idling and occasional lunge?
Recently replaced my dpf sensor G450.
before and now my car will run fine for a few days then all over a sudden my car will go from idling about 8k to sitting around 10? and occasionally lunge as in you feel the car move or jump slightly.
also occasionally drives a little lumpy, for instance 3rd gear just moviing thru the rpm's and you feel it go lumpy before picking up again?
Edited by wolverineuk
Thats normal during a DPF rengen cycle
Really?
would having a stage 1 and the DPF removed stop it from happening?
yep, def normal for a DPF regen, my car is a pig to drive when it does that...
Yeah DPF removal and mapped out will stop it,
doesn't necessarily have to be a stage 1 map, some places including Shark offer a stage 0 just to map out the dpf if insurance etc. is a problem
