Cd changer
Has any one got problems with there cd changer at all? Mine doesent want to play any cd's and it's not ejecting them eyther.
Any one got any thoughts at all on how to solve the problem?
Does your rear windscreen washer work OK?
Is there power going to it? Are the lights on?
+1. This might sound like a random question but if the pipe has popped off it is often near the cd changer and the electrics can get goosed by the fluid leak...
Its the fact that someone thought it was a good idea to have one clip to hold the electrical and hose connectors so that any leak from hose sprays straight onto the electrics.
The rear water jet doesent work since I had the car. There is power getting to the unit. On the main display its saying "cd error".
im un able to platy any cd or get them out!
Do everything else electrical at the back work (boot lights, rear lights, remote opening etc)? Sounds like it could be a water leak problem. Can you hear the pump run if you try and wash the back windscreen?
Mines shot as well. It lights up and when you push load the lights cycle but won't accept discs. HU shows no CDs. Anyone selling one ?
Have you tried depressing and holding the eject button for a few seconds?
No, I'll give that a bash.
Ive got full electrics. The funney thing is that the radio goes off when the car is started after its been standing for a while. Switch engine off then restart it and it works! :/
Fault code scanning time.
Tried the eject button , no joy , unplugged and reconnected still just cycling and no fault codes. Will phone scrappys tomorrow to see if they have one. The one on eBay at £56 is not worth it
If the problem is caused by a leaking hose then the connector on loom side could be corroded so another changer may not work.
No leaking hose , dry as a bone.
CD's what are they!?
:D
