octavia 1.8t 4x4 1u2 ferodo ds 2500s
hiya guys does anyone no which ds 2500s i would need on the octy elegance 4x4 i believe disc sizes are 288mm it is a mk1 as have looked around and cant seem to find anything any links/help would be much appreciated
Why not stick 312 on as will make a huge difference
as just put discs and pads on all around but is going stage 2 shortly so need the brakes unless anyone has set of 312s going cheap with calipers and carriers
312 setup uses same caliper
eg you can use the same pads
Does seem a bit of shortage of DS2500 pads at mo
Plenty of DS3000 about though (+ £10 roughly over DS2500)
..so the upgrade for 312mm brakes is just change the disk?
You need the carrier too
Thanks SM,
that makes more sense! hmm... phonecalls to motorfactors Friday afternoon!
