air con problem
hello all
I have a skoda Octavia which the air con seems stopped working, I regased it last year which disappeared after couple of days.
this year I decided to sort it out, I took it to a local garage who had experience with air con, they filled in gas and tried to find where it leaks from, but they couldn't find any place of leak, the gas disappeared again, I took it to many places since then, no one can find out where the leaking problem is and where the gas is going to/? any ideas would be appreciated.
hello all
It's probably leaking at the TXV or the evaporator. If the garage is relying on UV dye, they can't see the leak. Find somewhere that has a sniffer.
I have a problem with my air con it doesn't lose any gas but the air con won't come on I think it is the pressure switch
