urgent help required
So fitting my bluetooth unit which ran all wires found place for heat unit so putting all back together and I can't get the head unit back in with that big ass connector and suggestions really stuck now
thanks
Either take the top box out and play with it from above or route the quadlock to the side of the cage. The top box just eases out with a plastic spatula and then you just need to disconnect the hazard switch.
One option that can help is to remove the top storage box. Just gently prise the edges with a trim removal tool or old credit card and it will pop out. Push hazard switch through and unclip.
With that out you then have the ability to reach down and manoeuvre some of the wiring, before pushing the headunit back into place.
Thanks guys I've got it re routed the quad lock...... now on the loom there are two spare plugs do i just leave them??? They are ones female the other male both two wire with different wires coming into each other..... They look like they plug in to each other
Can you post picture of them?
They do plug into each other to support voice control.
Ok thanks i have done that now
so now all fitted this is what I'm left with if I now press phone I get this come up I haven't done any vcds coding..... now is this the point I need to tell the car it had bluetooth fitted??? I scanned for my car my phone bluetooth and it's not picking it up
Which bt unit is it?
It's the same one you gave me a link to on ebay the other day bolero unit..... i haven't got the software to do vcds coding this is basically just after I plugged everything in and switch it on
3C8035730D
For this part number i used to get the unit
It needs the pairing to be done in maxidot. Have you tried that?
No not yet as i haven't got the gear to do it..... i have a friend who does but isn't sure how to do it on the skoda system
It may work without coding. Just make your phone discoverable and try from the maxidot menu...
I have no option to go phone on maxidot its just standard screen must need coding.....
Yes agreed, 77 telephone needs ticking in the gateway module 19...
Then code up module 77 using the coding helper. The last two bytes are 01 01, which is not obvious from the helper.
Adam
Thanks mate appreciate that... Once done I take it i can use my phone to play music over bluetooth too and voice.commands
Yes you can and more if it connects in premium rSap mode. Which phone is it?
It's a samsung galaxy note 2 mate
Yeah that will connect in rSap mode so you can get SMS read out too for example.
Oh that's cool I love a good gadget so another thing for me to mess around with
