Interiur light doesn
Hi Guys,
My interiur light doesn´t turn off when I close the door. I´m suspecting a faulty lightswitch, but where is it located? Is it located at the end of the black door hingde?
Could it be something else than the switch?
Bgds Dan
Sounds silly, but nobody's nocked the slider switch on the light have they?
No the slider switch seems to work and are set correctly.
Do you have maxidot? If it was a door switch the display would also show the door as open. You've probably thought of that already though.
Good point.
Even the standard display has a little red picture that illuminates when a door is open.
