fitting roof rails
Hi all .. don't know if anyone can help me I recently bought an Octavia ambient TDI estate, it does not have roof bars, which I am told by Skoda is unusual,  I have managed to get some from a breakers yard, but I am not sure if I can secure them with self tapping screws or are they bolted from the inside, if I peel back the black tracking there appears to be plugged holes I am guessing theses are where its secured but I wanted to get some info before I attempt anything,  thanks
I wouldn't think self tapping screws was the right thing to use - more likely bolts!
Hi thanks Mike so when you say bolted from the outside, does the bolt go into the car roof . and through the rails if so  what holds the bolt in place. I cant put a nut on the end without doing it from inside .or am I missing something  thanks
The bolt does not protrude through the roof into the car's interior.
As long as it's the right length Mike! ;)
No estate versions of the MkII Octavia came without roof rails in the UK, however this post suggests that some non-UK entry level Octavia estates did come supplied without the roof rails...
http://www.briskoda.net/forums/topic/175557-can-you-remove-the-roof-rails-on-the-octavia-estate/
So either your car is an import or the previous owner has removed them.
Plenty on eBay...
http://www.ebay.co.uk/itm/SKODA-OCTAVIA-ESTATE-MK2-PAIR-OF-ROOF-RAIL-RAILS-BAR-/321356733573?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4ad25a9c85
You can see the threaded bolts in this listing above.
And other pair...
http://www.ebay.co.uk/itm/SKODA-OCTAVIA-ESTATE-2004-2008-BLACK-ROOF-RAILS-RACK-/121278925777?pt=UK_Car_Accessories_Touring_Travel&hash=item1c3cc98bd1#ht_1795wt_1275
Ooo, not sure Mike, I did a quick search on here (which revealed our other thread :p ) and a quick Google image search for 'Octavia Ambiente' to check, nothing cropped up.
I'll take another look to see what I can find...
Hi thanks to all, when I went into the skoda dealers, they said roof rails were an option but it was unusual not to have them, but my car was originally  a company car so I guess it was to save a bit, maybe they had several, the Garage wanted £500 pounds to fit them Ha. going to pick them up tomorrow from the breakers for £40 pounds, I might need more help let you know how it goes ..
