Torque App test results
Hi,
I brought a OBD II adapter and the Torque Pro App. Gave it ago the other day, did a test and it come up with lots of mombo jumbo stuff. i had a few Pass and Fails. I'm still trying to work the app and understand it but not having much luck with this. Could anyone kindly give any advice about my results? Many thanks
Mode $06 report generated by Torque for Android
Vehicle VIN: Not present
Vehicle Manufacturer: Unknown
Vehicle Calibration ID: 03D997033F
7001
Unit and scaling information are not supplied with the data from the ECU for this type of vehicle. Consulting the manufacturers service book for this information is recommended.
Test report:
TID:$01 CID:$01
- Rich to Lean sensor threshold voltage(constant)
Max: 64
Test result value: 27
PASS
TID:$02 CID:$01
- Lean to Rich sensor threshold voltage(constant)
Min: 2,458
Test result value: 3,404
PASS
TID:$02 CID:$02
Max: 17,203
PASS
TID:$02 CID:$06
Max: 37,356
Test result value: 32,768
PASS
TID:$02 CID:$07
Min: 28,180
PASS
TID:$02 CID:$08
Min: 34,079
FAIL
TID:$02 CID:$09
Min: 33,239
FAIL
TID:$02 CID:$0a
Max: 39,322
PASS
TID:$04 CID:$01
- High sensor Voltage for switch time calculation
Min: 46
FAIL
TID:$04 CID:$02
Min: 1,966
Test result value: 8,843
PASS
TID:$06 CID:$01
- Lean to Rich sensor switch time(calculated)
Test incomplete or dependant test failed
TID:$06 CID:$02
End of report.
Can't really help directly.
Came across this on the tdi forum
http://forums.tdiclub.com/showthread.php?t=391922
Hope that's of some help.
Did you try clearing the faults and then rescanning to make sure everything that comes up is current and not old data?
32768 is a threshold in binary/octal/hex - computer speak. I'd guess that's the limit of the sensor or reporting mechanism rather than a "real" value.
VCDS Lite would do a better job. Have you got a decent laptop?
